Ka wont start - Any suggestions?
Old Nov 1, 2011 | 06:24 PM
Gazz_'s Avatar
Gazz_
Default Ka wont start - Any suggestions?
I have having problems starting my Ford Ka.
It has a Focus 1.8 engine in it. I think it has something to do with PATS. It started once with the Focus ECU in it but will not start since.
I have the key and transponder from the Focus so I dont see how there would be a problem with the PATS system.
Any ideas?
Engine is cranking but will not fire up.
Old Nov 1, 2011 | 06:30 PM
foci's Avatar
foci
if its the PATS the l.e.d will be repeatidly flashing above the clock if you still have it.
Check for spark??? Listen for fuel pump when ignition is turned on
Old Nov 1, 2011 | 06:38 PM
Gazz_'s Avatar
Gazz_
I am sure I can hear the fuelpump when the ignition is turned on.
Will go and check the light just now.
Did you mean, put the key in and just turn it 2 turns (dont try and start it) and check the light on the clock?
Or check the light at the same time as I am turning the key?
Old Nov 1, 2011 | 07:47 PM
Gazz_'s Avatar
Gazz_
Just check the car.
When the keys are turned 2 turns the light flashes more rapidly.
And goes a solid red light when the other key (Focus key) is not inserted.
The fuel pump is working and there is a spark also.
So does that mean it is most certainly the PATS system that is preventing it?
Because as I was aware the PATS system stops the spark and fuel.
Any other suggestions as this is doing my fucking nut in !!!!
Please help.
Old Nov 1, 2011 | 08:41 PM
RichieST's Avatar
RichieST
It should go solid red when ignition is on, then go out a few seconds later. If it flashes fast then it's detected a problem.
Hold both keys together and start it with whatever one turns in the barrel. That was it should pick up the pats signal from good key yet it will start with the other. If that works then just tape up the other key inside the plastic cowling to permanently de-activate the pats for now.
Old Nov 1, 2011 | 10:08 PM
Gazz_'s Avatar
Gazz_
Tried that.
I just turns over but still doesn't start (just started the once).
I am getting a spark, fuel and the starter is turning.
What else could possibly be wrong?
Old Nov 2, 2011 | 06:53 AM
Churtz's Avatar
Churtz
Doesn't sound like a pats fault if you're getting fuel and spark, and it's turning over. That's normally a winning combination!! Lol.
When it started the once, did you turn it off or did it cut out? Was it running correctly?
Matt
Old Nov 2, 2011 | 12:35 PM
Gazz_'s Avatar
Gazz_
Matt
It was running fine.
I turned it off after a few seconds because there was no water in it. It was just a quick test fire to see if it would work.
If my postman hurries up I should have all the plumbing work finished today so will be almost complete (excluding exhaust).
I will try again today and let you know how I get on.
Old Nov 3, 2011 | 09:17 PM
Gazz_'s Avatar
Gazz_
Unhappy
I think the problem may have been a flat battery.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
