2wd cossie not starting ?
A mate of mine has an F-plate 2wd sapphire cossie which is now refusing to start.
Its definatly ignition related as when you switch the ignition on fully the coil starts to produce a spark but when you turn the engine over the sparking stops, hence why the thing wont start.
The coil is recieving a live when the ignition is switched on and stays live once cranking but will only spark when the engine is not turning over.
Any ideas people....
Paul
Paul
Oct 9, 2015 07:38 PM
rog
Sep 4, 2015 12:10 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
lockie
Jul 31, 2015 10:03 PM
