Turbo prob
Oct 31, 2011 | 12:59 PM
Turbo prob
Why does my T34 .63 not turn when idleing?
The car sounds like a normal car on idle aswell
Oct 31, 2011 | 01:06 PM
They don't necessarily, increase the revs slightly and it should...
Martin
Oct 31, 2011 | 01:07 PM
It will with a little rev But y would it sound like a non turbo from behind on idle
Oct 31, 2011 | 01:12 PM
Don't understand what you define by "non turbo", they don't have a unique sound really.
Martin
Oct 31, 2011 | 01:14 PM
Ok its not bubbly like a cossie its more a constant drone sound like a boyed up corsa sort of thing lol
Oct 31, 2011 | 01:18 PM
Oh see what you mean, tbh I always found they sound like Pintos, on which they are based, if it's not broke don't fix it
Martin
Oct 31, 2011 | 01:20 PM
it kinda is tho lol not alot of boost stage 3 tho
Oct 31, 2011 | 01:21 PM
What is the pressure?
Martin
under a bar dont even notice the boost
Oct 31, 2011 | 01:24 PM
Oct 31, 2011 | 01:26 PM
Oct 31, 2011 | 02:43 PM
No where near stage 3 at a bar that's for sure, weak actuator possibly.
Oct 31, 2011 | 03:36 PM
I dont know but need to sort it asap
Oct 31, 2011 | 03:38 PM
Could also be a big air leak, but u would be taking it to a well known tuberculosis and get it setup
Oct 31, 2011 | 03:39 PM
Tuner I ment Fucking phone
Oct 31, 2011 | 03:53 PM
Exhaust has a big part in the sound aswell
Oct 31, 2011 | 04:05 PM
Its going to the tuner by castle coombe
Mat it has a 3" scorpion with a 4" rolled out pipe
Going to check for air leaks later aswell
Oct 31, 2011 | 04:41 PM
If it's under a BAR you have something wrong, is your Amal valve working?
Martin
Oct 31, 2011 | 05:12 PM
It clicks thats all I know then
Oct 31, 2011 | 07:00 PM
Mine used to have a scorpion and it never had a burble noise but it has the mongoose on it now and sounds much better with a bit of burble.
Nov 1, 2011 | 01:24 PM
Quote:
Originally Posted by
cossie891
If it's clicking that is wrong, it should CLICK when the ignition is switched on (And so has power applied), clicking means it's being told to do so, i.e. bad TPS calibration, if not possibly a faulty valve.
Martin
Nov 1, 2011 | 01:26 PM
Thats what I mean it clicks with ign on and if I unplug it and plug it in etc as it should
Nov 1, 2011 | 01:31 PM
So it clicks and if you disconnect/connect the plug it doesn't click? First thing to do if verify it has a good power supply, WITH the engine running, could be a wiring problem.
Martin
Nov 1, 2011 | 01:34 PM
No it clicks like normal If I unplug it clicks if I plug in it clicks
Nov 1, 2011 | 01:45 PM
Oh I see so that seems to be working then, I thought you meant it was constantly clicking, maybe you have a boost leak/faulty actuator etc then...
Martin
Nov 1, 2011 | 01:47 PM
Nov 1, 2011 | 01:48 PM
i am going to check for air leaks later
Nov 3, 2011 | 08:44 AM
Defo no air leaks and it idles loike a cossie now I turned the idle down to 850 was on 900-950 now it sounds good
Still need to sort the boost out tho
Nov 3, 2011 | 10:53 AM
The turbo should spin on idle
All mine have
Steve
Nov 3, 2011 | 11:42 AM
have you dropped off the exhaust from the back of the turbo and had a look? Sounds like you may have lost a blade
Nov 3, 2011 | 11:58 AM
Its a new turbo mate and yeah I have looked at the blades and they all seem fine
The turbo spins at about 1k or with a quick poke on the throttle
Nov 3, 2011 | 01:19 PM
maybe a faulty turbo bud it happens as steve said and i would have thought myself all turbos should spin at idle as all mine have
Nov 3, 2011 | 03:17 PM
may be a bit tight after rebuild ,what does it fill like with your hand
Nov 3, 2011 | 04:52 PM
i bet its a 2wd manifold? they dont spin sometimes if the idle is low enouph,hence the non existant burble noise, this is normal,no faults here, just change of adjust the actuator to get the boostup.,and if you want it to spin on idle, raise the idle speed!
Nov 3, 2011 | 07:10 PM
There is NO fault, mine does not spin on idle.
Martin
Nov 5, 2011 | 08:50 AM
Cheers guys
It is a 2wd manifold I have spoke toa tuner and he said the same some times they dont spin
So all looks good I pos need a actuator tho
Nov 5, 2011 | 08:51 AM
Wilky the turbo spins easy enough by hand maybe a lil bit tighter than normal but there is no tight spots its the same all around
Nov 6, 2011 | 12:04 PM
Martin can you post a vid up of yours on idle from behind please
Any 1 know why the shaft wont spin and how to get the noise back
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
