Zorst still Fookin Scrapping, Standard springs the answer?
Old Oct 31, 2011 | 10:52 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Default Zorst still Fookin Scrapping, Standard springs the answer?
HI all. Sorry bit on an essay. End of my tether with this lol.
I have just fitted a magnex oe style exhaust to my saph 4x4. Now I am still scrapping everything if not a bit more considering the diameter of the exhaust pipes is smaller than my mongoose if have just taken off, and now I have taken a chunk out of the pavment tarmac going onto my drive which is on a hill and slant slightly down. I am planning on fitting standard ride height suspension. Will this cure it. Pic of them.
I have got the exhaust as high as I can for now but I think I can only get it up another 3 maybe 4cm's at a push. But I don thtink it will sort this problem.
My car is lowered only 25 mm so I dont eat the cv joints and on koni shocks all round.
I am going for Bayjoo standard ride height ones.
Does anyone else have this problem or am I the only one?
Who else has standard ride heightspirings?
cheeRS all.
Old Oct 31, 2011 | 02:43 PM
m4tt274's Avatar
m4tt274
i know plenty of cars that are lowered that dont scrape, what rubbers are you hanging it off? they may be to long or perhaps perished and soft allowing the exhaust to bounce
Old Nov 1, 2011 | 06:35 AM
kosienutter
New ford ones, but they may be on the wrong hole or something. I may also try and bend the metal bars on the exhaust itself and see if that helps.
Old Nov 1, 2011 | 03:00 PM
m4tt274's Avatar
m4tt274
what does magnex say it should be hung from?
Old Nov 1, 2011 | 03:10 PM
Harris.'s Avatar
Harris.
I have the same system as you on my 3 door only with a smaller back box, i solved it by hanging the system using the thinner closer holes on the rubber mounts ,ie turning them on there side . very tight fit and does the job any more probs pm me
Old Nov 1, 2011 | 06:43 PM
m4tt274's Avatar
m4tt274
i would imagine getting some really slim rubbers would sort it. also a check if your car is actually 25mm, all the springs ive ever bought have never been what they claimed
Old Nov 1, 2011 | 06:51 PM
kosienutter
harris, i will try and put the zorst on the side bits of the mount tomorrow once i have put my new discs on, have a look and hope it works. it was a bugger getting it on the longer gapped holes lol.
m4tt274, hope they are 25mm but i am suspisious sometimes as i do have a steepish angle on the front driveshafts when she is on the deck. dont know what magnex say to hang it on as it is a hardly used second hand one.
ill update tomorrow night.
cheeRS.
Old Nov 1, 2011 | 07:43 PM
Harris.'s Avatar
Harris.
good luck mate
Old Nov 1, 2011 | 11:44 PM
jimhc's Avatar
jimhc
big jc
my 2wd has 25mm drop on front and standard ride hight on on rear but stronger than standard the exhaust is fine unless its a killler of a speedbump
Old Nov 2, 2011 | 12:00 AM
botters's Avatar
botters
competant bodger
my 4x4 3 door is lowered more than 25mm and has never scraped the exhaust even on the biggest speedbumps and my centre box is huge lol!
Old Nov 4, 2011 | 01:04 PM
kosienutter
i said i would update but as you might have seen from other threads once i put my new discs on and went for a test run my shocks at the front rotted out and let go nearly writing of the front tyres lol. so it wont be till next weeks i can try and hang it higher. but now with new standard front shocks and springs the ride height at the front is higher at the mo.
till next week hopefully folks..
Old Nov 5, 2011 | 04:28 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Have you tried using Powerflex mounts???
Old Nov 5, 2011 | 10:21 PM
kosienutter
No just normal ford ones. Are the power flex stiffer and shorter?
Old Nov 6, 2011 | 08:04 PM
andycos's Avatar
andycos
I also have the exact same problem with the same spec 4x4 as yours
Took the mongoose off as it was catching where the front pipe goes from offside to nearside.
Decided that magnex was a better fit,and that now catches just behind the twin boxes where the joint is flanged one side,and slip on joint the other.
Think the cutting disc and mig welder are going to pay a visit to it soon
Old Nov 8, 2011 | 12:00 AM
kosienutter
Since my shocks collapsed last thursday I have put standard ride height springs and shocks at the front and it has raised the front (obviously). I am still planning hopefully this week to raise the exhaust so hopefully my problem is sorted.
STAFFY OWNER
Sep 13, 2015 08:59 PM
Marino
Sep 12, 2015 11:10 AM
Topjoe9
Sep 12, 2015 09:50 AM
focus2351
Sep 9, 2015 09:33 PM
Adam Graham
Sep 6, 2015 06:04 AM
