Fitting cossie rear beam to estate
Old Oct 30, 2011 | 09:28 PM
busa bob's Avatar
busa bob
Default Fitting cossie rear beam to estate
HI folks i got 1.8cvh sierra estate, also got rear arms, beam, brakes etc from cossie am wan2 fit them to estate
Had look under it today and noticed shocks go thru spring on estate and dont on cossie setup.
Wan2 know if this conversion possible so i got disc brakes on rear?
But also can i retain 1.8 diff and shafts? as shafts are push in on estate and bolt on on cossie?
Any info greatly appreciated
Rob
Old Oct 30, 2011 | 09:34 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
the hubs will just bolt on, the shafts...... hmmmmmm....... cant remember!
im 99% sure the drive flanges are all the same size in the hub.
www.fordsierraclub.co.uk or ask Dojj
p.s 4x4 (XR or RS 4x4) diffs are 7in same as your estate.
then you can build it all up with estate stuff, Only the wishbones and shocks/springs are different, beams and diffs are identical.
shafts interchange accordingly
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
