Cosworth Boosting problem help
Old Oct 29, 2011 | 02:41 PM
RSLUBBY's Avatar
RSLUBBY
Default Cosworth Boosting problem help
Hello
My 2wd cosworth has started to have intermitant boosting problems. One minute full boost one minute no boost and alot of sucking sometimes lower boost. Normally ok from cold fine then goes off and dont normally come back on till re started after cooled.
What to try to eliminate
Dump valve do i take off?
Amal Valve do i un plug?
What can i try
Thanks
Ian
Old Oct 29, 2011 | 06:59 PM
martysmartie's Avatar
martysmartie
Boost leak perhaps? Although if this is the case it makes the turbo work harder to achieve the same target boost pressure! No unplugging the Amal will LOWER the boost pressure!
Is the actuator good?
Martin
Old Oct 30, 2011 | 10:38 AM
RSLUBBY's Avatar
RSLUBBY
how do i test the actuator was on the car when i bought it and looks new!
Could it be a boost leak as one minute fine the other as if no boost. the sucking is the air filter
Old Oct 30, 2011 | 05:23 PM
qad's Avatar
qad
the best man to asked is joe@ GSMOTOSPORT 07940 181847
My mate had same sort of thing. joe told him what to do on the phone to sorted it. he always helpful good luck mate
Old Oct 30, 2011 | 05:27 PM
martysmartie
Lol thats normal for the air filter, it's kind of hard unless you have a pump etc to test, they do loose there strength after a while.
Martin
Old Oct 30, 2011 | 09:14 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
What Dump Valve is it??
Old Oct 30, 2011 | 11:38 PM
RSLUBBY's Avatar
RSLUBBY
Hi Matt Bailey piston type not dia not very old worked fine on me last car
Old Nov 1, 2011 | 09:38 AM
Matt Lewis's Avatar
Matt Lewis
never overlook a dump valve as they still can leak, blank it it off and try it
Old Nov 1, 2011 | 11:56 PM
RSLUBBY's Avatar
RSLUBBY
Will give it a go but otherwise gonna dump it at steve scotts as its proper doing me head in and got track days looming
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
Escortdriver1
Jul 31, 2015 02:36 PM
