gt35 turbo
Hi peeps just wondering iv got a gt35 turbo can I bolt that straight on the std comp yb if so what sort of boost power should I expect thanks
slotting the beam to allow the correct toe adjustment changes the semitrail arm angle so is no longer a 6 degree beam
designing it properly and correctly with double adjustable rose jionts allows correct geometry setting without moving the pivot points from the set 6 degrees
I recall a few years ago when I was in Malta. Guy there had a standard bottom end, GT35 and about 35psi boost.
Also Skyline box fitted too. White 3 door.
Seemed to work well for him ! I'm almost sure it was running either high 10's or low 11's
It certainly isnt ideal or optimal. And will no doubt be very laggy. But it will still be capable of making decent power
JK12
33
Apr 26, 2021 12:09 PM
