Bodywork prep help please!
Old Oct 24, 2011 | 08:20 PM
steveo6946's Avatar
steveo6946
Kontact
Default Bodywork prep help please!
Hi. About to start all the prep to re spray my p100 but have no idea what sanding equipment I need. What grade discs? I know I will need finer discs but this is my first go so clueless!!! Got to start sometime tho Any help much appreciated. Cheers
Old Oct 24, 2011 | 08:32 PM
whizzisat114's Avatar
whizzisat114
if the panels are good (no repairs) id use red scotch and 600 wet and dry if your using two pack primer or
grey scotch brite and 800 if your going wet on wet
Old Oct 24, 2011 | 08:44 PM
steveo6946's Avatar
steveo6946
Kontact
Well the panels are good but the strips along the door and body are being removed and the holes filled along with the the rear bumper corners. Spraying it mat black. What primer do I need to use? This is my first go at it so only going from what info I'm finding out. Cheers mate.
mk1turboestate
Dec 2, 2015 08:31 PM
rsguy
44
Sep 29, 2015 03:29 PM
Kam B
Sep 24, 2015 10:40 AM
jonnyenglish
Sep 21, 2015 07:31 AM
coscor86
Sep 20, 2015 01:21 PM
