Compbrake TCA's
Old Oct 23, 2011 | 11:10 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Default Compbrake TCA's
I've been offered a set of Compbrake TCA's for my saph.
I remember seeing on here that someone had some issues with their compression struts but just wondered if the TCA's are any good?
Cheers,
Gaz.
Old Oct 24, 2011 | 12:10 AM
Fast_Wyvern's Avatar
Fast_Wyvern
Ive had Compbrake TCA's on my RS for about 5 years, only problem I had was in the first year, Camber was set to - 3 degrees and the wheel bearing failed on the way into ford fair.
New wheel bearing and reset the camber to about -1.9. No more problems. Watch out for the body of the TCA catching on the chassis. Had to use washers to space it out
Old Oct 24, 2011 | 06:31 AM
JamesH's Avatar
JamesH
Make sure they're gen Ford ones that have been modded, and you should be ok
Old Oct 24, 2011 | 07:15 AM
RSGARETHW's Avatar
RSGARETHW
always working
Gaz sent u a message on rsoc
Old Oct 24, 2011 | 01:57 PM
Ridgey's Avatar
Ridgey
Mine have been great, loads of abuse and trackdays, only thing is they are a bugger to adjust on the car as it's difficult to get a spanner on the adjusters (cross member is in the way). Can't complain though the car itself was not designed for adjustable stuff therefore access is difficult.
But once they are set spot on
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Mark V8
Sep 13, 2015 09:34 AM
yatta
Sep 1, 2015 11:28 AM
155lee
Aug 14, 2015 11:21 AM
