PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   General Car Related Discussion. (https://passionford.com/forum/general-car-related-discussion-12/)
-   -   Compbrake TCA's (https://passionford.com/forum/general-car-related-discussion/410054-compbrake-tcas.html)
Gazzonator Oct 23, 2011 11:10 PM
Compbrake TCA's
I've been offered a set of Compbrake TCA's for my saph.
I remember seeing on here that someone had some issues with their compression struts but just wondered if the TCA's are any good?
Cheers,
Gaz.
Fast_Wyvern Oct 24, 2011 12:10 AM
Ive had Compbrake TCA's on my RS for about 5 years, only problem I had was in the first year, Camber was set to - 3 degrees and the wheel bearing failed on the way into ford fair.
New wheel bearing and reset the camber to about -1.9. No more problems. Watch out for the body of the TCA catching on the chassis. Had to use washers to space it out
JamesH Oct 24, 2011 06:31 AM
Make sure they're gen Ford ones that have been modded, and you should be ok
RSGARETHW Oct 24, 2011 07:15 AM
Gaz sent u a message on rsoc
Ridgey Oct 24, 2011 01:57 PM
Mine have been great, loads of abuse and trackdays, only thing is they are a bugger to adjust on the car as it's difficult to get a spanner on the adjusters (cross member is in the way). Can't complain though the car itself was not designed for adjustable stuff therefore access is difficult.
But once they are set spot on :top:
© 2026 MH Sub I, LLC dba Internet Brands
