Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Ford focus mk1 brake bleeding
Old Oct 23, 2011 | 04:22 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
Default Ford focus mk1 brake bleeding
Hi,
What's the best way to bleed the brakes on a Mk1 Ford Focus ghia ????.
Ta,
Dave.
Old Oct 23, 2011 | 04:45 PM
martysmartie's Avatar
martysmartie
The same way as any other system, so start with the corner furthest from the M/C (So Offside rear first and work your way in) clean all dirt away from nipples first, remove dust cap and loosen the bleed screw and connect a sutiable tube over the nipple with the other end immersed in the end of a container containing clean brake fluid, get your assistant to pump the pedal until clean fluid, with no air bubbles is seem coming from the nipple, at which point close the nipple WHILST they have there foot still depressed on the pedal.
(Two man method)
At no point allow the M/C to run dry on fluid.
This apply's to ABS models as well which yours most certainly is.
Martin
Old Oct 23, 2011 | 05:04 PM
SWITCHBLADE
So O/S rear, then N/S rear, then O/S front, then finally N/S front ????.
Dave.
Old Oct 23, 2011 | 05:35 PM
martysmartie
Got it in one
Martin
taylora1409
Aug 12, 2015 12:06 PM
hazbaz1984
Jul 30, 2015 05:15 PM
