General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
That's trick it's abit like the tool that you use for hex,s but abit more advanced and prob with a high price tag, to be honest I'd just prog" in pocket mill and tell it what I want and bob,s your uncle
I'm not a machinist but deal with components that need a square hole through them for use with 8 and 10mm key steel. That looks like an interesting tool!
We usually have to have a hole like that wire eroded. The options were either wire erosion, spark erosion or smashing a mandrel through it at the time we we're first starting to use key steel.
clever peice of kit, on that application it looks good and could save time, but i wonder how it would hold up on harder metals, and larger and deeper holes, as i could see rigidity being an issue.
It is cool. But the tool is not rotating in a circle. You can see the chuck is not rotating in a circle either.
It's just moving fast so it looks like it is.
I'd imagine they've been around for years in slightly different forums. Looks very good. Its how they put the hex's on allen keys etc, (well very similar) obviously they'r done on a lathe.
It would be clever if it did rotate in a circle .
Worked on the design of early CAD machines in the 70's we were struggling to get it to cut screw threads back then . This is clever & ive not seen it before but ive been retired 5 years. Bloody Chinese.
