Cosworth Switch Panels
Need ideas and inspiration for an switch panel to hold the switches for fans, anti-lag, lauch control and flamer.
Please post up what you have as i need to start collecting any bits for this.
Also put your gauges too
cheers
ran
cheers
ran
What about using the idiot-light panel above the clock and fitting the switches into that?
I have an XR4i one that goes all the way across but if your door-ajar display has been removed it could look "right".
You would need the early version with 6 lights in it and then simply drill out the plastic "very carefully as it's known to be as delicate as a butterfly's wing" and then simply insert radon push switches into the panel
not sure about that as there will be 4 switches and i want a light for each switch to indicate when it is on so need space for that too
That's why I suggested the early full-width version - like Dojj says, it had 6 lights in it so should be able to take 4 switches and telltales, or you could use switches that illuminate when active?
3dr cossie
21
Nov 20, 2015 05:00 PM
Aug 14, 2015 07:29 AM
