Head gasket question
For instance if my head was skimmed to much and i needed a thick gasket to compensate for the lack of gap lets say, would i be able to use 2 multi layer steel ones or best just 1 thick one??? anyone tried this or think i am a *&^%$"£*& moron lol.
Tom
head thickness is also critical for other reasons, i.e. amount of material holding the valve seats in place. if its over skimmed, then its not really ideal to use it without some extensive repair work.
otherwise this can happen
Thanks mate i will give them a bell.
Thanks to all the advice above and i was thinking i was being a *&%£""*( Moron lol.
I am not sure on the exact thickness yet as i am away in Afghan right now, i will post size when i return and see what everyone thinks, iirc 138mm is the standard size i am sure it's been skimmed once, i only really want to keep the head because it has has some light port and polish wok done, i will see thanks again chaps.
Ok slight update, stripped and cleaned it today (well as much as i could) before any work has been done on the head and block i have noticed that the valves are already ever so slighty touching the pistons, that was with a 12 yr old gpa gasket, does anyone know the thickness of these compared to the 5 layer multi gasket, when they say 2.00mm is that the compressed thickness that they will be after fitment or starting thickness???
andrewmctiernan
Sep 8, 2015 03:05 PM
