What size tyres for 4x4 Saph?
Old Feb 18, 2005 | 03:50 PM
boon's Avatar
boon
Default What size tyres for 4x4 Saph?
Hi
Just got a set of 17" for my 4x4 Saph, but can't decide what size tyre to go for - 205/40/17 or 215/40/17.
What do you guys recommend?
Also, I'm thinking of Yoko AVS - anyone recommend anything better?
Boon
Old Feb 18, 2005 | 04:00 PM
EssexBoyRacer's Avatar
EssexBoyRacer
The correct size for 4x4 saph is 215/40/17.
Old Feb 18, 2005 | 04:12 PM
mřffe's Avatar
mřffe
no it´s not standart wheel diameter are
205/50-15...... 1790mm
205/40-17.......1818mm
215/40-17.......1842mm
so the closest fit is the 205/40-17 but im driving on 215/40-17 on my sierra and theay fit fine. no problems. and theay are a littlebit softer ride.
Old Feb 18, 2005 | 04:16 PM
EssexBoyRacer
thats strange
I was told by a m8 who is a tyre fitter, and Lepsons when I got my wheels refurbed that the correct size was 215/40/17.
Old Feb 19, 2005 | 12:09 PM
boon's Avatar
boon
Cheers,
If the 215/40/17 fit without any probs then I might as well get those.
Old Feb 19, 2005 | 06:16 PM
dark3drcos.kickass's Avatar
dark3drcos.kickass
both these sizes are correct as the205/215 is the width not the profile so both have same diameter it depends on wheel width you take standard tyre size and take off 5 on profile for every inch bigger
Old Feb 20, 2005 | 01:35 PM
2litresi's Avatar
2litresi
i run 215 on my rwd 205 bends the wheels to easy as there is not a lot off tyre and bf goodrich are very good run them on mine
Old Feb 20, 2005 | 01:55 PM
noodlesblacksaff's Avatar
noodlesblacksaff
i run falkens cannot fault them
Old Feb 20, 2005 | 02:56 PM
mřffe's Avatar
mřffe
you forget one thing mate.. 205/215 are in mm(millimeter) and 40 are in % that will say that on a 205mm wide thire, the side are 82mm high:
205x0,40=82mm high tyre sides
215x0,40=86mm high tyre sides.
not mutch i know.
and of course 17 are in inches
Old Feb 20, 2005 | 05:14 PM
boon's Avatar
boon
Thanks to all for posting..
Upshot seems to be that 215/40/17 fit without problems even though the 205/40/17 is a closer match to the original 205/50/15.
I should have said from the off that the car is lowered (about 25mm i think), and the wheelarches haven't been rolled (and i don't want them rolled)... bearing that in mind, 215/40/17 still the size to go for?
Old Feb 23, 2005 | 12:02 PM
Mr.Ford's Avatar
Mr.Ford
i have 215/40/17 in the summer, and 195/5015 in the winter
Btw. My car is also lowered by yellow Koni's , and Apex (yellow) springs
No prob's at all
Nov 3, 2015 04:08 PM
slammedorion
15
Nov 1, 2015 07:17 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
