dohc sierra ignition vs zetec trigger
Old Oct 19, 2011 | 03:06 PM
haadee's Avatar
haadee
Default dohc sierra ignition vs zetec trigger
Is the missing bit of 36-1 on the same position on flywheel like a zetec?
If so I should be able to use mondeo coil pack+ecu or not ?
(believe its 90 degrees BTDC on zetec)
racing one of these in a contact formula so I would like to change it as the ignition is on the front on these engines standard.
cheers
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
BRAM
Sep 8, 2015 07:11 AM
yorkie92
Sep 6, 2015 05:34 PM
hopper350
Sep 4, 2015 12:53 AM
