Turbo dampner help
Old Oct 19, 2011 | 01:38 PM
killa_paul's Avatar
killa_paul
Default Turbo dampner help
as above i got this from a mate and have no fitting instrutions so dont know how to adjust it properly
can someone tell me how to make sure its adjusted right ?
see photo
Thanks paul
Old Oct 19, 2011 | 01:49 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
its not a damper its a hanger it just helps with the weight of the turbo on the manifold
Old Oct 19, 2011 | 07:25 PM
Ridgey's Avatar
Ridgey
It damps the vibration though !!!!!!
Anyway, undo the top bolt, warm up the car to normal temps and then adjust the length of the fitting so you can fit the top bolt back in. Lock the length with the lock nut.
Old Oct 19, 2011 | 08:29 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Makes the vibration worse , the rs500 version stops the vibration/resonance as i have found out after swapping from the hanger type to the horseshoe type
Steve
Old Oct 19, 2011 | 08:30 PM
ajamesc's Avatar
ajamesc
Sorry but how can it dampen its ridged its there to take some of the strain off the manifold studs by supporting the weight from the top.
Old Oct 19, 2011 | 10:22 PM
chrisa3's Avatar
chrisa3
Looks like 4x4 head. Is it sitting on a 4x4 manifold?? if so the damper / hanger isnt needed is it ??
Old Oct 20, 2011 | 12:08 PM
Ridgey's Avatar
Ridgey
Restricting movement.
Old Oct 20, 2011 | 03:38 PM
bigluke200's Avatar
bigluke200
As above, used to get an evil vibration between 2&3k rpm with that style of hanger
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
