Runs and stops????
Old Oct 19, 2011 | 07:31 AM
mark_24v_wiring's Avatar
mark_24v_wiring
Unhappy Runs and stops????
Morning all
Its a 2wd turns over starts runs for approx 3 seconds then stops.
As soon as you touch the throttle it dies so it wont rev up either.
try to re-start it and it does.
Things i have checked so far;
Cap,rotor arm,leads,coil,ignition pad,injectors,spark plugs,TPS,lugs on crankshaft sensor and sensor gap and all the wiring back to the ecu to make sure there isn't a broken wire.
Any suggestions??
Thanks in advance
Old Oct 19, 2011 | 07:55 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
i wont say anything
Steve
Old Oct 19, 2011 | 08:35 AM
boost mad's Avatar
boost mad
map sensor could be the issue
Old Oct 19, 2011 | 08:38 AM
mark_24v_wiring
edited
Old Oct 19, 2011 | 10:24 AM
martysmartie's Avatar
martysmartie
MAP sensor as said (Overfuelling) check the hose, and this first, the "flash code" system will also indicate a fault with the sensor.
If good, also do the "Wiggle" test on the CPS connector as they are known for having bad connections but would not have your symptoms.
Martin
Old Oct 19, 2011 | 10:31 AM
mark_24v_wiring
Right thats the place to start then 2 people saying the same thing has to be a good sign
Thanks guys will report back later no at the car till 6pm
Old Oct 19, 2011 | 10:33 AM
Shonky's Avatar
Shonky
V6 Ka of Love
Does the fuel pump remain running after the car starts? Running for a few seconds always makes me think it's running on the fuel in the lines it had when the pump primed
Old Oct 19, 2011 | 10:40 AM
mark_24v_wiring
As its a race car the pump is controled via it's own switch not the ecu so yes it does continue to run
Old Oct 19, 2011 | 10:52 AM
JamesH's Avatar
JamesH
Have you changed anything since it last ran?
A mate changed a phase sensor and got the wires back round the wrong way, which gave similar symptoms to this
Old Oct 19, 2011 | 11:00 AM
mark_24v_wiring
no nothing has been changed yet
Old Oct 19, 2011 | 04:49 PM
mark_24v_wiring
Taken plug off map sensor car runs all be it rich as but changing the map sensor over for a new one makes it do exactly the same runs for 3 sec won't rev and stops
Old Oct 19, 2011 | 09:15 PM
boost mad's Avatar
boost mad
In that case, as you mention the smell of fuel, check your ECT sensor, the blue on at the back of the head on the inlet side
Old Oct 21, 2011 | 03:21 AM
mark_24v_wiring
Worked it out it was a mapping issue
Thanks for the help
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
fuzzy
Sep 4, 2015 10:11 PM
