SECS Monitor max boost reading
Old Oct 17, 2011 | 11:13 AM
Sonic Boom's Avatar
Sonic Boom
Default SECS Monitor max boost reading
I am right in thinking the max boost reading on a SECS monitor is 30.0 psi?
Cheers Rich
Old Oct 17, 2011 | 11:52 AM
James @ M Developments.'s Avatar
it depends what Map sensor you are using.
Old Oct 17, 2011 | 12:05 PM
KSA-Cossie's Avatar
KSA-Cossie
Mine peaks at 28.5 psi iirc
Old Oct 17, 2011 | 12:14 PM
martysmartie's Avatar
martysmartie
In theory yes as it probably only has a conception of a 3 BAR MAP sensor and thus the maximum boost it could read would be 2 BAR or 30PSI.
Martin
Old Oct 17, 2011 | 12:28 PM
3dr cossie's Avatar
3dr cossie
mine max's out at 28.4 psi
Old Oct 17, 2011 | 04:31 PM
Sonic Boom's Avatar
Sonic Boom
3 Bar, but in the options you can only select 2.0 2.5 or 3.0, so if you had a 5 bar would it just go all screwie?
My Apexi boost gauge reads 2.3 bar but the peak recall on the SECS just says 30.0 psi so I presume it's maxed out.
Rich
Old Oct 17, 2011 | 04:48 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
im shore when i had one before going autronics mark told me they only go to 30psi when he fited one in mine
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
I think it is 30psi. See what the alarm limit is and I think that would be it
Old Oct 17, 2011 | 05:37 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
28.4 on mine
Steve
Old Oct 17, 2011 | 06:49 PM
Rich
yeah if you had a 5 bar it would read all wrong, but simon did tell me he could re calibrate them to work. Would be ideal to run one on its own 5 bar sensor.
doubt it will EVER happen though
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
