hart inlet / small turbo t/body whos done it?
Old Oct 17, 2011 | 10:22 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default hart inlet / small turbo t/body whos done it?
has anyone used a hart inlet with a small turbo escort throttle body? i need a pic of your throttle cable bracket
Old Oct 17, 2011 | 12:07 PM
KSA-Cossie's Avatar
KSA-Cossie
Kitchen devil (gaz) off here is doing it mate
Old Oct 17, 2011 | 01:01 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
As Kev said I will be doing it soon.
Just as soon as I cross his palms with some silver for the throttle body!!
Old Oct 17, 2011 | 01:08 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
That's my inlet but not sure how the clearance would be with the ISCV fitted as they are quite long, could turn it around perhaps?
Actually, looking at the angle of the ISCV, it may well clear the bracket ok!
Old Oct 17, 2011 | 01:44 PM
ajamesc's Avatar
ajamesc
I havent got mine back yet as there having trouble sorting the bracket out. So if they carnt ill make some thing up when i get it on the car just wanted to see what others have done but it dont look that bad looking at yours . Joe said he was going to get someone to make some thing up along the lines of the 2wd one they sell (looks like 2 bits of wire with the mount in the middle) But then looking at your pic there isent the bracket meant to sit in front of the throttle body
Old Oct 18, 2011 | 04:40 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I need to know as well
What size thread is the big vacum hole ?, is it the same as the big one in the middle of a 2wd inlet ?
Steve
Old Oct 18, 2011 | 07:33 AM
ajamesc's Avatar
ajamesc
whats the big vacum hole? mine has a plate welded over some thing that once lived at the bottem of it
Old Oct 18, 2011 | 07:45 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Any pics of the hole you're on about Steve?
Old Oct 18, 2011 | 08:11 AM
Turbosimpsons's Avatar
Turbosimpsons
he means the large tapped hole above the holes for the map sensor ect.
Old Oct 18, 2011 | 10:07 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
M14x1.5
Old Oct 18, 2011 | 04:37 PM
BRAMMER's Avatar
BRAMMER
My bracket is from Spec R - think off the top of my head they are around £40
One thing i found with mine is the hole taps in the inlet to mount the fuel rail is slightly high in the lug and make the rail sit slightly higher at the front which is making me nervous - i know mine ran on Dave Escos (who i bought it off so it must have been fine) but check yours to make sure
Also if anyone has the size and thread of the small holes for the vacuum fittings can you post it up
Old Oct 18, 2011 | 04:47 PM
andy escos's Avatar
andy escos
the small vac pipe take offs are 1/8npt
Old Oct 18, 2011 | 04:51 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Your TB is not a ST Escos one
Steve
Old Oct 18, 2011 | 06:06 PM
BRAMMER's Avatar
BRAMMER
Cheers Andy
Steve
Steve it doesn't matter your throttle linkage looks to have the same principle as the 2wd - if you look at where the throttle bracket goes around the part where the ISCV fits the ST is more vertical so clearance issues wouldn't be an problem - the only thing is you have a different bolt diameter but i'm sure Pete can sort that for you.
See from this picture they are virtually the same and the bracket i have would work for that
Old Oct 18, 2011 | 07:20 PM
ajamesc's Avatar
ajamesc
Ive been told that the linkage is a problem by joe stevens thats whys he is trying to sort out what to do at the mo he says he has only done a few on that throttle body. Thats why id asked on here as i may have to make my own bracket which dosent bother me but just wonted to see what others may have done when using the escort throttle body
Old Oct 18, 2011 | 08:47 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I will wait so i can just bolt it on, im no mechanic lol
Steve
Old Dec 12, 2011 | 03:14 PM
mbfordnut's Avatar
mbfordnut
Brought a cable bracket from spec r
chopped and welded it to fit
Old Dec 12, 2011 | 03:21 PM
ajamesc's Avatar
ajamesc
thats looks good mate ive got mine now just waiting to fit it all when i can be arsed!
Old Dec 12, 2011 | 03:23 PM
mbfordnut's Avatar
mbfordnut
Glad u got it sorted. Just a headache to fit. Is it going in a 4x4? You'll have to move two brake pipes if so. Literally a few mm..
Old Dec 12, 2011 | 03:40 PM
ajamesc's Avatar
ajamesc
na going on a rear wheeler i may mod my power stearing at the same time to electric with merc a class stuff like my mate has anyway! just have to see how keen i am lol
Old Dec 12, 2011 | 03:53 PM
mbfordnut's Avatar
mbfordnut
Ah fair enough. I guess these inlets get pretty close to the 2wd power steering pump then. Mines a late 4x4 so its under the turbo but I did have to move the fluid bottle off the wing as that was hitting too
Good luck with it all
Old Dec 12, 2011 | 06:33 PM
flannigan's Avatar
flannigan
i was going to go this route but in the end i gave up waiting for joe to sort out a throttle bracket so i bought a proper rs500 plenum in the end
Old Dec 12, 2011 | 07:17 PM
ajamesc's Avatar
ajamesc
it did take a long time but he had a few made! i only waited as its only 500 pounds and the gains it gives can be so good with the right bits! you just have to look and what they got out of it on rods engine over the rs500 one
Old Dec 12, 2011 | 08:06 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
So you paid out twice as much for the sake of a bracket
More money than sense
Steve
Old Dec 12, 2011 | 08:26 PM
RONNIE AMIS's Avatar
RONNIE AMIS
yikes!!! that looks a bit of kit
Old Dec 12, 2011 | 08:28 PM
mbfordnut's Avatar
mbfordnut
Cheers mate. Just a little bit of nitrous being used
Old Dec 13, 2011 | 03:34 PM
flannigan's Avatar
flannigan
Steve
i was lucky as i bought it off a good mate and it was really cheap at £800 plus i took into account that you have to mod quite a few things to get the heart plenum to fit all in all it prob worked out at the same price imo !
Danielbetty
Oct 3, 2015 06:01 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Cosnada
Aug 27, 2015 09:15 AM
Aug 20, 2015 09:21 PM
IAN RS2k
Aug 18, 2015 07:51 PM
