Storing a cosworth over winter
Hi I'm storing my car this year in my concert garage with a breathable cover, I've not done this before but has anyone got any tips? I here condensation can be a problem? I've got a battery conditioner so no problems there, anybody?
When.i put mine away i just park it in the garage nad take the battery lead off.I then go to the car every few weeks to go and start it up.
Some people put there cars on axle stands to stop the tyres from getting damaged.
mines on scaffolding boards,with a cover on,handbrake off and tyres pumped upto 50psi to stop flat spots,i also leave bowls off salt around it to draw moisture away,i dont start it i leave it then crank it by hand when it ready to come out again.
edit,its got two caravan dehumidifiers in with it aswell.
Thanks for replys lads, am I best to leave engine or turn it over every other weekend for 10-15 mins? I heard cissies can kill plugs ect doing this, any other tips? Parking on carpet make a difference?
on axle stands so the tyres dont fold if they go down and crank with the king lead off to get the oil recirculating back round when its back in use
kosman,,, fuck me thats alot of winter prep work !!!
- Give it a proper clean, inside, outside, arches, underneath etc to get as much shite off it as possible.
- Stick it in the garage
- Put it on axel stands, take wheels off and leave other wheels underneath it in case the stands fail.
- Leave the sunroof/window open slightly.
- Keep a battery conditioner hooked up.
Cheers,
Grant
Cheers,
Grant
mines has been sat in the garage since i came back from knockhill show this year just been walkin to work and savin nd tryin to build the zetec mk1 sierra and the 3dr cossie
Martin
Don't leave a full tank of fuel in it or it'll go off and drive like crap, then end up posting on here about why your Cossie's sick after being left for 6 months.
Leave a dribble, or enough to run it a bit.
My winter Cosworth procedure goes like this: leave tow rope and jump leads in boot, check coolant, oil and fuel. Drive. Simples.
Personally though if I were to have the luxury of a garage, I wouldn't disconnect the battery lead - they're easier to nick when the alarm's not squealing for attention. And it's an arse re-programming the radio stations.
Leave a dribble, or enough to run it a bit.My winter Cosworth procedure goes like this: leave tow rope and jump leads in boot, check coolant, oil and fuel. Drive. Simples.
Martin
I reckon that for the minute amount of current they drain, it's not worth removing it. After all, if the alarm's disabled, chances are that your insurance is too. If the battery's in good nick anyway, it shouldn't really matter. While it's rare that mine's idle for a long period it started after 4 months of being idle (see "sick"), but was alarmed the whole time, first turn of the key, even with a relatively naff battery.
Leaving it on a trickle charge is surely a better way if you are gonna put them into hibernation?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
