Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
St170 Induction KIT What one to get?
Old Oct 16, 2011 | 01:39 PM
ThePoons's Avatar
ThePoons
St170
Default St170 Induction KIT What one to get?
Isit worth getting an induction kit for a st170? if so what one is the one to go for? The all enclosed ones made by Pipercross the Viper i think its called? or is the stock just as good i.e is it a waste ofr £180 for the kit.
Thanks in advance
Danny.
Old Oct 16, 2011 | 01:50 PM
alexno1dj's Avatar
alexno1dj
if your looking for any gains its a total waste of money, id spend time getting a decent cold air feed to the airbox and give the maf a good clean
N/a engines dont benefit from induction kits tbh
Old Oct 16, 2011 | 01:54 PM
ThePoons's Avatar
ThePoons
St170
maf? ok ill look for a air pipe any recomendations? get rid of the stock air feed you suggest?
Old Oct 16, 2011 | 01:58 PM
alexno1dj's Avatar
alexno1dj
id get a better cold air feed going into the air box. how you choose to do this is up to you but id run an alloy or larger pipe down towards the bumper. Yeah the MAF is the aluminium part in between the air box and throttle body. i gave the inside of mine a good soak in carb cleaner and made a smoother tick over.
Spend your money on a replacement panel filter for the air box, ie k&n.
Old Oct 16, 2011 | 01:59 PM
alexno1dj's Avatar
alexno1dj
st 170s rarely make the power they should so a good service would be my starting point
Old Oct 16, 2011 | 02:06 PM
ThePoons's Avatar
ThePoons
St170
I brought it this weekend, its all standard i dont want to go away from its stock stuff really as im guessing its tune to the parts there. and it does look neat and tidy, ill be servicing it tomorrow at work fuel filter plugs oil and filter, and then a K&N element from ebay? just bored on a sunday and having a look at induction kits ect
Old Oct 16, 2011 | 02:09 PM
alexno1dj's Avatar
alexno1dj
yeah you will find after a good service it will make a difference. Definatly buy the k&n element over an induction kit, the airbox will keep the inlet temps much cooler than a cone filter. Either way the st170 is a nice drive,
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
