turbo 10.25- 1 comp engine ?
Old Oct 15, 2011 | 09:49 PM
scoooby slayer's Avatar
scoooby slayer
Default turbo 10.25- 1 comp engine ?
on a cast bottom end but rpm only 5500 rpm max im curious how much boost it could take on v power and power pour ?
i realise not much but im only thinking of 8 - 10 psi max ?
its on a chevy v8 btw
Old Oct 15, 2011 | 10:04 PM
Joshy's Avatar
Joshy
Dreamer
Running Boost with high compresion lends itself to high RPM's rather than low one's.
Depending on the chevy then you might be able to run maybe 5 or 6psi with water injection with some decent heads.
If you could get some pistons and rods from an earlier engine then you might be able to lower it to maybe 9:1 which would run your 10 psi I think.
big_Rad
Sep 15, 2017 09:36 AM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
