Ford Range This section is for other models in the Ford range.
Transit 2.4 TDDI DMF non start ???
Old Oct 14, 2011 | 06:50 AM
kev 3dr's Avatar
kev 3dr
Default Transit 2.4 TDDI DMF non start ???
Would a DMF failure/worn cause a 2.4 tddi engine not to start and would it produce any fault codes ??
Old Oct 14, 2011 | 08:52 AM
Danwood79's Avatar
Danwood79
If the starter is full of clutch dust then the starter would fail,
some manufactures of the starter like FRIESEN (QH) uprated the dust seal in the starter to stop premature failure.
If the transit is 2000-04 you could think about a solid flywheel replacement.
Dan
Old Oct 14, 2011 | 10:01 AM
kev 3dr's Avatar
kev 3dr
Dan
Cheers Dan but know most of that anyway just trying to work out if this could be the fault before i go ripping the clutch out on my back as its already had injectors,pump,pipes filter & head, sender unit and crank sensor and many hours of head scratching
Old Oct 14, 2011 | 10:35 AM
chaffe's Avatar
chaffe
Turbocharging Technician
did you do the timing and oil pump chain when the pump was off? they are bad for going too
Old Oct 14, 2011 | 10:54 AM
kev 3dr's Avatar
kev 3dr
Not yet mate no want it running first before i throw anymore money at it especially if flywheel clutch want doin as theres at least Ł150
Old Oct 14, 2011 | 01:25 PM
chaffe's Avatar
chaffe
nightmare, bring back the old DI!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
