Ford Range This section is for other models in the Ford range.
cosworth boa v6 help needed, whos got one??
Old Oct 13, 2011 | 06:11 PM
petemos's Avatar
petemos
Default cosworth boa v6 help needed, whos got one??
hi looking for a little help and knowing where a vacuum hose from the inlet manifold is meant to go?? its the one right in the middle at the back of the inlet manifold? car is idling badly and this hose has been blocked of. there is also a regulator of some description on the left hand side of the engine with no hose on it at all, just wondered if they should be joined.... bought the car like this....... cheers
Old Oct 13, 2011 | 10:46 PM
skinnarbi's Avatar
skinnarbi
Tyres - It's What I Do
Sorry To run off topic but It's not a blue saff with a 24v in is it?
Regards
Matt
Old Oct 14, 2011 | 04:49 AM
3drpete's Avatar
3drpete
Block them off mate
Old Oct 14, 2011 | 06:47 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it's for the egr stuff, bin it
but if it's not been wired up properly then this may cause issues
Old Oct 14, 2011 | 03:18 PM
petemos's Avatar
petemos
hi, cheers for that.. its in a 3 door cossie replica 4x4 24v. im having problems with it idling and when i change gear the revs go up a little........ sounds like i cant drive !!! also could i just unplug the o2 sensors or am i better leaving them connected??? am going to clean iscv tomorrow see if that helps, it seems to pull ok higher up the revs but lower down not so good..... any ideas????
Old Oct 14, 2011 | 03:20 PM
chaffe's Avatar
chaffe
Turbocharging Technician
I put mine to the brake servo
Old Oct 14, 2011 | 03:40 PM
petemos's Avatar
petemos
also my speedo isnt working could that be it ?? as i think they have a speed sensor somewhere??
Old Oct 14, 2011 | 08:28 PM
dojj's Avatar
dojj
if it's a granada then yes, it has a speed sensor, but if it's got an mt75 or type 9 box bolted to the back then someoens not hooked up the speedo cable
JoeyBoyden
Jan 4, 2024 02:36 PM
Aug 14, 2015 07:29 AM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
