Shaking front end
Old Oct 13, 2011 | 09:36 AM
boost mad's Avatar
boost mad
Default Shaking front end
Saph cossie 4x4
Ive got a shake between 80-95 and when cornering left over about 60. At first i thought it was a unbalanced wheel or a buldge in the tyre so took the wheel off to have it rebalanced and its all fine.
The issue wasnt there before i took the car off the road about a month ago to do the sump seal. the only things that were touched would be the crossmember and engine mounts. Could it be something to do with them ?
Old Oct 13, 2011 | 03:07 PM
scotty4130's Avatar
scotty4130
First thing I'd do is get back under there and do a quick check with a socket that all crossmember and engine mount bolts are tight. If that's ok, I'd check the ball joint in the track control arm for play, then I'd check for play in the wheel bearings.
Old Oct 13, 2011 | 06:29 PM
Paul_RS's Avatar
Paul_RS
Could be a fucked front driveshaft too.
Wilsfoci
15
Mar 30, 2016 10:26 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Bezzy41
Aug 3, 2015 10:31 AM
