Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
de cat on rs 2000 mk6
Old Oct 9, 2011 | 07:39 PM
r.s.2000 ginger's Avatar
r.s.2000 ginger
Default de cat on rs 2000 mk6
Thinking of putting a de cat on my car does it make much of a diffrence in power or does it just sound as if it does. Thanks
Old Oct 10, 2011 | 06:40 AM
oldford's Avatar
oldford
I have tried it in the past on a lot of cars and measured them on a rolling road.
Usually it gives you 0 (Zero) to 1 (One) bhp extra. Without any other changes to the engine pretty useless, except when the current cat is blocked.
Old Oct 10, 2011 | 02:36 PM
r.s.2000 ginger
Would it need a new compleat exhaust on it for a de cat to make a diffrence.
Old Oct 10, 2011 | 03:07 PM
escort4x4's Avatar
escort4x4
It doesnt really release any extra horses but it does change the note of the exhaust
I would advise fitting a complete stainless system, the engine will breathe a bit better as stock exhaust is restrictive. Ull like the note change of the exhaust,
Old Oct 10, 2011 | 03:19 PM
r.s.2000 ginger
Ok thanks boys think i will as i got a original ford system on it.
Old Oct 11, 2011 | 12:50 PM
STeve's Avatar
Super Moderator
I have a complete magnex inc de cat on my 4x4 ,this with a superchip and a decent cold air feed will give you around 16bhp increase
Old Oct 11, 2011 | 01:38 PM
r.s.2000 ginger
That sounds good i can see me getting a new system and a superchip then thanks mate.
Old Oct 11, 2011 | 07:16 PM
STeve's Avatar
Super Moderator
no problem
Old Oct 15, 2011 | 09:58 AM
v man's Avatar
v man
Zee Germans are coming
my wifes car ( escort gti) has a piper stainless rear section
ive just fitted a stainless 4 branch with decat and the difference is unreal
the engine revs alot more freely and harder
pulls harder and sounds good to
now im looking for a decent induction kit
some 130 spec cams
super chip
maybe get a spair head and get it ported
Old Oct 19, 2011 | 07:54 AM
STeve's Avatar
Super Moderator
some 130 spec cams
super chip
I know someone that has done all these mods and reached 139bhp on the dyno
Old Oct 19, 2011 | 11:31 AM
r.s.2000 ginger
Thanks for the replys the reason i asked is because someone told me to find out about putting a de cat on before i do it as it might lose power and i dont want that as it hasnt got that much to start with.
Old Oct 20, 2011 | 01:48 PM
v man's Avatar
v man
is that good then
Old Oct 20, 2011 | 06:43 PM
STeve's Avatar
Super Moderator
is that good then
for a normal 115ps without a turbo or bike carbs etc it is
Old Dec 11, 2011 | 05:29 PM
fogulbennett's Avatar
fogulbennett
1-pd does your car pass its mot when it is de-catted?
Old Dec 11, 2011 | 05:58 PM
STeve's Avatar
Super Moderator
without the superchip it would fail totally , it just squeezes through with it when running really hot which is a relief
Old Dec 11, 2011 | 06:01 PM
fogulbennett
Ok mate where about is the cat? Is it in the manifold on a mk6
Old Dec 11, 2011 | 07:01 PM
r.s.2000 ginger
Its just after the manifold.
Old Dec 11, 2011 | 07:27 PM
Fordmad!'s Avatar
Fordmad!
I had a rs van and took the egr off and a decat and i had 164.4bhp on the dyno!
Old Dec 11, 2011 | 07:51 PM
fogulbennett
So I'll need too buy a whole system and new manifold come mot time! Gutting
Old Dec 11, 2011 | 07:55 PM
Mark_'s Avatar
Mark_
my old rs2k 4x4 always passed the emissions without the cat being fitted
Old Dec 11, 2011 | 08:00 PM
STeve's Avatar
Super Moderator
no point in having a decat if running with a stock system tbh as its pretty restrictive, the decat can be fitted onto the std manifold ok , what was mentioned was to have your original manifold modded to remove the APS to get the most out of your exhausts air flow but you dont have to, and run with a power/superchip 164 ish is a easy target
Old Dec 11, 2011 | 08:33 PM
fogulbennett
I don't have a stock system I have a 4-2-1 stainless manifold then full 2 1/2" system so I'll need too buy another system for mot time?
Old Dec 11, 2011 | 08:49 PM
STeve's Avatar
Super Moderator
you may be lucky if running a decent chip to aid better fueling, when I first took mine for a mot it was way up, then fitted a superchip and and it squeezed through
Old Dec 11, 2011 | 08:56 PM
fogulbennett
Not superchipped
Old Dec 11, 2011 | 09:00 PM
studabear's Avatar
studabear
Mot regs change next year, it will be a fail if the cat is not fitted on a car that it should be even if it passes the emission test
Old Dec 11, 2011 | 09:04 PM
fogulbennett
Oh yea so they do so cat time in march for me
Old Dec 12, 2011 | 06:06 AM
STeve's Avatar
Super Moderator
unless you know a freindly tester, who tells you folk the de-cat was fitted after the mot of course
gambo08
Feb 4, 2016 10:49 PM
Nov 1, 2015 06:53 PM
little bram
Sep 27, 2015 07:45 AM
