de cat on rs 2000 mk6
Thinking of putting a de cat on my car does it make much of a diffrence in power or does it just sound as if it does. Thanks
I have tried it in the past on a lot of cars and measured them on a rolling road.
Usually it gives you 0 (Zero) to 1 (One) bhp extra. Without any other changes to the engine pretty useless, except when the current cat is blocked.
It doesnt really release any extra horses but it does change the note of the exhaust
I would advise fitting a complete stainless system, the engine will breathe a bit better as stock exhaust is restrictive. Ull like the note change of the exhaust,
Zee Germans are coming
my wifes car ( escort gti) has a piper stainless rear section
ive just fitted a stainless 4 branch with decat and the difference is unreal
the engine revs alot more freely and harder
pulls harder and sounds good to
now im looking for a decent induction kit
some 130 spec cams
super chip
maybe get a spair head and get it ported
some 130 spec cams
super chip
Moderator
some 130 spec cams
super chip
some 130 spec cams
super chip
Thanks for the replys the reason i asked is because someone told me to find out about putting a de cat on before i do it as it might lose power and i dont want that as it hasnt got that much to start with.
Moderator
no point in having a decat if running with a stock system tbh as its pretty restrictive, the decat can be fitted onto the std manifold ok , what was mentioned was to have your original manifold modded to remove the APS to get the most out of your exhausts air flow but you dont have to, and run with a power/superchip 164 ish is a easy target
07-10-2015 12:56 PM
