Comp Test on FRS
Old Oct 9, 2011 | 11:25 AM
Ben26's Avatar
Ben26
Default Comp Test on FRS
Got a mate who has a mk1 Focus RS and he has done a compression test due to a bit of a worry , he got the following readings:
160psi
160psi
160psi
155psi
The pistons and stroke are stock at 8.0:1 i think thats what it is anyone
what are peoples thoughts on this and what should it be , is a 5 psi drop satisfactory ?
Ben
Old Oct 9, 2011 | 12:11 PM
rsturbonutter's Avatar
rsturbonutter
i wouldnt worry about the 5psi drop if it where more lioke 25 35 drop i would investigate but that is nothing to worry about
Old Oct 12, 2011 | 08:50 PM
dredge3's Avatar
dredge3
Its fine.Put a splash of oil in then re test
Old Oct 16, 2011 | 08:47 AM
GUZZLER's Avatar
GUZZLER
Get a leak down test done, that will give a better indication of the engines condition.
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
TPM961
Jan 15, 2018 10:50 AM
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
