Breaking XR2 Zetec Turbo Project -NICE BITS INSIDE
Thinking of getting rid completely of the car.. I fancy doing something else, but I want the bigger more expensive bits to go first.. So drop me a PM
Zetec Turbo Wossner Pistons and Fardon Rods. 86mm for Silvertop Brand New - SOLD
Zetec TurboAccralite 86mm Forged Pistons, Brand New - SOLD
T3/T4 Turbo with Brand New Wastegate + Tubular Manifold for Zetec - SOLD
Longlife Exhaust - SOLD
HO Inlet Manifold - £80
Subaru 44cc Side Fed Injectors - £50
Brand New Gaz Coilovers with Polybush Top Mounts - £380
Willwod Superlite 4 Pot Brakes, comes with Adapters and Used pads. No Discs - £270
2.0 Block, Head etc, all in bits, was gonna use with pistons - £50
Modified Sump with Oil Return and Baffled - £50
1.8 Sump and Pick up - £40
1.8 Flywheel + RS Turbo Clutch - £50
Brake Lines Braided - £30
Airtec Radiator, has had a repair but perfectly useable - £130
Blue Silicone Hoses, with all joins, brand new jubilee clips and temp senders etc - £150
S2 RS Turbo Gearbox, rebuilt begining of year with new bearings and selector forks - SOLD
IB5 rear starter box - SOLD
Hubs, with bottom arms, polybushed - £50
Tiebars with Bushes - £25
Bodykit, no cracks but faded here and there - £50
Bumpers - £50
Rear Axle Setup - £50
90 Spec Recaros - £100
Interior which is rear seats, door cards, carpet, rear panels etc - £60
XR2 Dash with Clocks - £70
Driveshafts - £40
Pepperpots, good condition. Tyres little left on them - £50
ARB Clamps. Brand New Gen Ford Still in Packet - SOLD
Spot Lights - £20
Doors - £50
Facet Pump - £20
Filterking Fuel Reg - £25
Strut Braces - £60
Shell, as you know ive stripped it right down. Its got the glass, loom and steering coloum in it as well as the tail gate. Ill do a deal on it as it is with the doors, bonnet and rear arches, sills and wings ready to fit for £150
Ive got loads more to list.. but like I said guaging interest at the moment... PM me..
Bumpers - £50
Driveshafts - £40
Spot Lights - £20
Doors - £50
Facet Pump - £20
Strut Braces - £60
Hello mate would you happen to have the "2.0 Block, Head etc, all in bits, was gonna use with pistons"
If so, I have a mate whos after it, but isnt on here.
Would you be able to stick on a pallet and get paisley freight to send it?
Billy_RS
16
Oct 11, 2025 09:41 PM
