'52 Plate Fiesta 1.4 TDCI won't start! Help
Old Oct 4, 2011 | 10:02 AM
Hickleys's Avatar
Hickleys
Exclamation '52 Plate Fiesta 1.4 TDCI won't start! Help
Hi there,
I'm having problems with a fiesta tdci. I won't start. I was shut down one down day then never restarted. No dtc's are coming up. It has perfect fuel pressure at cranking. It will crank for approx 3 seconds at which point fp reaches 1600 bar and the car stops cranking. I have scoped the cam, crank, and throttle signals they are all correct. I have all signals at the ecu terminals, but i have no ijection output from the ecu. No immobliser lights are on and all keys are correct. I have heard there is an issue with the rolling code in the pcm, which i have had reset and re paired with the HEC and still no injection pulse.
Any ideas?
Thanks for your time
Old Oct 7, 2011 | 03:27 PM
Hickleys's Avatar
Hickleys
No one?
Old Oct 7, 2011 | 04:14 PM
oldford's Avatar
oldford
Normal pressure when cranking on diesels is around 250 - 300 bar.
1600 bar is overdoing it a little bit.
Old Oct 10, 2011 | 10:06 AM
Hickleys's Avatar
Hickleys
I know... at cranking it has 300 instantly, as the injectors aren't pulsed it has no where to go. 1600 bar is the point of safety where the pcm says fuel rail overpressure if the car is running, if its cranking then it cuts the starter to stop the pressure build.
Old Oct 10, 2011 | 10:33 AM
andrewg's Avatar
andrewg
metering valve on pump stuck? i think if pressure is + - 60 bar disired it will shut down?
Old Oct 10, 2011 | 11:12 AM
Hickleys's Avatar
Hickleys
Would of though i'd get an injection pulse before it shut down though. :S
Old Oct 11, 2011 | 08:15 AM
Hickleys's Avatar
Hickleys
I forgot to mention...
If you crank the car, the engine turns over for approx 2-3 seconds, then stops. Key off, then on and you can re-crank again for 2-3 secs like before... If you do this maybe 10+ times the engine will the spin over as long as you want it to, but with minimal fuel pressure. When it does this longer cranking its bringing up a cam sensor fault. But the sensors are working , as said previously i have scoped them. And it won't bring up this fault be just cranking for 2-3 secs. Very confused!
Any idea?
Old Jan 25, 2015 | 08:03 PM
Gaile Stoskuviene's Avatar
Gaile Stoskuviene
Any idea?
JoeyBoyden
20
Aug 22, 2015 03:23 PM
loughlin1
Ford Fiesta
Aug 20, 2015 10:42 PM
creator
Aug 2, 2015 12:24 PM
