Cosworth 4x4 Wiring Loom Identification
Oct 3, 2011 | 09:34 PM
Evening guys,
To ensure I have the correct connections in the right place, can you guys help with the identification?
1: End of the loom - Distributor, PF08, Idle Valve, Knock Sensor or spare
2: Middle of the loom - Water Temp Sensor, Oil Pressure Sensor, ???
3: Middle of the loom - ????
4: Top of the loom - ????
5: Top of loom - ????
6: Top of loom - Ignition Module????
7: Top of loom - MAP Sensor????
8: Top of loom - ????
9: Top of loom - ????
10: Top of loom - ????
Oct 5, 2011 | 06:20 PM
Oct 5, 2011 | 07:51 PM
no 10. diagnosic plug i think
9 . amal valve
8. coil
4. 02 sensor
Oct 5, 2011 | 07:52 PM
ogg the top of my head i don't know what 3 or 5 is the rest you have identified
Oct 6, 2011 | 08:26 PM
Oct 6, 2011 | 08:52 PM
did the car have air con that it came off? to could be to do with that
Oct 9, 2011 | 07:48 PM
Not sure, I'll need to pm th chap I bought i off. Thanks
How does it connect to the fuse box or power?
Oct 9, 2011 | 07:58 PM
5 is the connection for the engine loom to the car, num 3 i think is the lambda sensor wire.
Oct 9, 2011 | 08:09 PM
Cheers herb. I'm not running a lambda so will just tie it to the side.
Is the ignition amp for a 2wd different than a 4x4?
Oct 9, 2011 | 08:21 PM
i dont think there different mate
Oct 11, 2011 | 01:00 PM
the loom used to be mine and i bought it off Paul Ripley who i assume had it off an escos.
No idea if it ran air con or not - sorry
Oct 13, 2011 | 09:46 AM
If you can pin it out and tell me where the pins go back to on the main ecu connector then i will be able to tell you what they are for
Oct 13, 2011 | 05:07 PM
Number 3 is canistervalve ?
Oct 13, 2011 | 07:09 PM
Whats the canister valve? Where is it located?
Oct 13, 2011 | 10:56 PM
it was on escorts i belive
Oct 14, 2011 | 09:12 PM
I found a diagram so sorted now cheers
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
big_Rad
Sep 15, 2017 09:36 AM
jay030787
Sep 18, 2015 07:34 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
jdsjojo
Aug 1, 2015 08:50 PM
