saff cossie T3 turbos
Just a quick question which i think i know the answer to but just want to be certain.
Are 2wd drive saff cossie T3 turbos different to 4x4 saff cossie T3 rurbos.Are they different where they bolt onto the manifolds cause i know the 2wd saff manifold is different to a 4x4.
Near enough but a 2wd t3 has studs in the bottom of the exhaust housing to mount on the 2wd trouser section
The 4x4 has the studs on the manifold. So there are holes for them on the turbo.
If you use a 4x4 t3 on a 2wd you can use short bolts with nuts
But if you are using 2wd on a 4x4 you have to take the studs out and drill to 8mm I think .
Hope this helps
Hope this helps
Billy_RS
16
Oct 11, 2025 09:41 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
