Ford Range This section is for other models in the Ford range.
1988 xr3i cabby running problems
Old Oct 2, 2011 | 11:37 AM
mikey28's Avatar
mikey28
Default 1988 xr3i cabby running problems
hi i am new to the site and to ford engines and was hoping for some advice.
i have just been given a 1988 xr3i cabriolet by my sister,it was running ok but very tappety until i took the rocker cover off the other day,what i found inside the cover was shed loads of solidified oil and i mean loads(quarter of carrier bag full!) once i had removed it all and made sure oil strainer and pump was clear i put new oil in(15/40 semi) and also new oil filter.
started it up and it sounded great! then when it started warming up it got very tappety and started miss firing and oil pressure light came on so swithed it off.
ive had lifters out and they only seem to have very very minimal wear on them.it was running fine until i cleaned away the sludge please help im a bit stuck as of what to try next. any help very much appreciated.
mike
Old Oct 2, 2011 | 11:50 AM
mikey28's Avatar
mikey28
just realised ive posted in the wrong section,didnt see the xr range section,can this post be moved there please?
sorry
mike
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
stevierob
Aug 11, 2015 09:08 PM
Zoggon
Aug 10, 2015 10:39 AM
marky_g
Aug 8, 2015 08:23 AM
