Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Puma rear axle beam
Old Feb 17, 2005 | 04:19 PM
PUREtom's Avatar
PUREtom
Default Puma rear axle beam
Quick question,
are all puma rear axle beams the same?
And are the puma rear beams for bush type shocks or fork type?
Please help
Thank you
tom
Old Mar 2, 2005 | 04:44 PM
cooler king's Avatar
cooler king
no they arent all the same!
depends on whether or not its the early or the late puma. the suspension arrangement that connects to the axle. the early axles use spacers behind the breaks, these can be removed whereas the late pumas have the spacer welded on to the actual axle!
i have an early puma but i have the later type suspension setup but off the fiesta as it doesnt have the spacers on it, so it works better with the rear disc set up off a focus as! hope this helps a little!
Old Apr 10, 2005 | 01:44 PM
AdamB's Avatar
AdamB
doubt thats the case as the puma is based on the mk4/5 fiesta, there are 3 types, the mk4 fitment (fork), the mk5 (eye), and the mk5 z-s/puma (eye and stiffened)
IIRC for a mk3 fiesta you need the mk5 eye type
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
