Undoing puma crankshaft pulley bolt...
Old Oct 1, 2011 | 10:52 AM
turbotrev's Avatar
turbotrev
Default Undoing puma crankshaft pulley bolt...
Doing a cambelt on a ford puma but have come across a problem removing the crank pulley bolt. I know when it's all timed up the crank sits against the timing pin so doing the bolt up is not a problem but how do you undo it as when you turn the crank anticlockwise it just turns? I have another longer timing pin in the kit so is this used some how? Guessing I need to lock the crank completely to undo this pulley bolt?
Totally stuck now so if anyone has a clue?
Thanks in advance, Paul M
Old Oct 1, 2011 | 11:44 AM
gouch1's Avatar
gouch1
home made tool to lock crank pullys ect
http://www.google.co.uk/imgres?q=cra...0&tx=134&ty=67
Old Oct 1, 2011 | 02:33 PM
Churtz's Avatar
Churtz
Put vehicle in 4the gear. Off clutch. Stand on brakes as hard as poss. This will hold the engine still.
Matt
Old Oct 1, 2011 | 03:39 PM
stoke7up's Avatar
stoke7up
take the starter off and lock the flywheel
Old Oct 1, 2011 | 05:32 PM
turbotrev's Avatar
turbotrev
Cheers for the info fellas, will try these methods first thing tom morning, nice one
Cheers Paul
Old Oct 1, 2011 | 05:43 PM
Sp3no's Avatar
Sp3no
DONT use the timing pin to hold the crank it will bend and will not hold.
Also do not use the cam locking tool to hold the cams when loosening the cam pully as that will snap the end of the cam off
Old Oct 2, 2011 | 12:39 AM
turbotrev's Avatar
turbotrev
No worries sp3no, does this apply when tightening the crank pulley too?
Old Oct 2, 2011 | 01:02 AM
botters's Avatar
botters
competant bodger
yes DO NOT use the locking pin to hold the crank while tightening the bolts, use an air gun to remove and refit the bolts, then torque the bolt up after locking the flywheel either with a prybar or make yourself a tool to bolt across two of the starter bolts and lock against the ring gear like i have made
if you do not do the crank bolt tight enough it will come loose and wreck your engine
also as above do not use the cam locking bar to hold cams while loosening pulleys as you will snap the end of the cams use a 21or 22 mm spanner on the correct location of the cam to hold them
Old Oct 2, 2011 | 07:19 PM
turbotrev's Avatar
turbotrev
Ok, well finished off the cambelt today and all is good so thanks guys.
Used the 4th gear and applying the brakes method with using an electric gun to get the pulley off in the end, and all went well.
Cheers Paul
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
Ben26
Sep 3, 2015 07:55 PM
