Lol @ volvo, dunno if you can use the powersteering from it but if you can get a powersteering rack to fit your mk4 you can easily install a power speering pump with the mk5 bracker, all you will need it the diferent bottom pully, alternator pully and the tensioner to take the wider pas belt, alternatively go for a pug 106 eletric pump
Whats the point its just more hassle and wear and tear on other components. I dont think it would fit because steering shaft connects to the steering rack on the left hand side.
