will
Old Sep 23, 2011 | 10:51 PM
coolj's Avatar
coolj
Default will
Hi ever one will a 1.8 throttle body fit a 1.6 zetec and will it do any think
Old Sep 23, 2011 | 11:02 PM
phil_rs's Avatar
phil_rs
yam yammer
No and no
Old Sep 23, 2011 | 11:12 PM
coolj's Avatar
coolj
Originally Posted by phil69a
No and no
Oh ok sum one said to me today that they do fit little f**** lucky I asked first bfor I got it. Is it only cam change that I can do to get more power from my 1.6 iv got exhurst decat and k&n just tring to think of others
Old Sep 23, 2011 | 11:18 PM
phil_rs's Avatar
phil_rs
yam yammer
The 1.6 zetec is different in design to the 1.8 and 2.0 so very little is interchangeable. Cams and throttle bodies would see the most gains. Have a look for fiesta zetec s tuning as I believe they have the same engine as your focus
Old Sep 23, 2011 | 11:38 PM
coolj's Avatar
coolj
Wot throttle bodys wod fit and wot wod I take off zetec s if its same engine
Old Sep 24, 2011 | 12:13 PM
phil_rs's Avatar
phil_rs
yam yammer
Sorry my post was a little confusing. No standard Ford parts will make your car faster. You need to look into aftermarket cams and throttle bodies. e.g.
http://www.ebay.co.uk/itm/Omex-Throt...ht_1055wt_1064
Old Sep 24, 2011 | 05:15 PM
coolj's Avatar
coolj
Iv just found out that iv not ever got an exhurst system on my car its all standerd apart from bk box so got to get one soon when I find out wot is wrong with my car
Old Sep 26, 2011 | 08:26 PM
martysmartie's Avatar
martysmartie
Your engine is the Zetec S! You can get around 140HP, you need exhaust, induction and cams, remap etc, this is a featured package from Shaw Speed, it's not that cheap however!
The similarity ends with the name with the larger engines (Zetec-E), they are completely different and bare no resemblance.
Martin
Old Sep 26, 2011 | 09:11 PM
coolj's Avatar
coolj
Martin
My engine says on the top zetec se
Old Sep 27, 2011 | 06:08 PM
martysmartie
Zetec SE AKA Zetec S AKA Sigma, same engine!
Phase 1 engines, with the metal cam cover had Zetec S on the cover later ones, had the black cam cover which you will have with Zetec SE written in white/grey writing. Earlier models had this scribed into the cam cover
Example:
Your engine:
Phase 1 engine:
This is the one and only avaliable engine in this capacity for the car, the 1.4 is also the same engine.
Martin
Old Sep 27, 2011 | 07:01 PM
coolj's Avatar
coolj
Example:
Your engine:
Phase 1 engine:
Martin
Ok thanks do u no if my car is an obd or obd2
Old Sep 28, 2011 | 01:26 PM
martysmartie
99.9% OBD2, in fact I think all petrol engined cars from 2001 had to be, by way of law!
Martin
Old Sep 28, 2011 | 01:32 PM
coolj's Avatar
coolj
Martin
Ok thanks alot hoping to sort hunting out by weekend if I can find wot is wrong with the thing
Old Sep 29, 2011 | 08:22 AM
martysmartie
You need to discover how the speed is being raised, it can only do so via the ISCV or the throttle, unless you have an air leak else where. If the former then an incorrect input to the ECU will be telling the valve to operate in this way.
Martin
Old Sep 29, 2011 | 08:55 AM
coolj's Avatar
coolj
Martin
Sorry iv not got a clue wot u r on about but put it on computer and cum up with no codes at all so now im lost on wot it can b
