Bit of compressor help needed!!!!PLEASE
Old Sep 23, 2011 | 02:25 PM
2ndGear's Avatar
2ndGear
Default Bit of compressor help needed!!!!PLEASE
I have a FIAC Airforce 3phase AF17/200 compressor.
About 2 months ago it would not build pressure above 2bar (it usual runs at app roc 10bar), this was sorted as i got a service pack and replace the gaskets and seals.
Its been fine since then but now it gets to 11bar blows the relief valve down to 9bar and then just keeps running like that. It won't hold pressure at 10bar.
Does it sound like the relief valve is faulty or something else?
Old Sep 23, 2011 | 02:46 PM
Turbosimpsons's Avatar
Turbosimpsons
i'd say it's the pressure switch.
Old Sep 23, 2011 | 04:24 PM
vaughant's Avatar
vaughant
Christ that's a lot of pressure,their usually set to about 6bar max (90 psi)?
Old Sep 23, 2011 | 04:53 PM
andy escos's Avatar
andy escos
as said above its the pressure switch that starts & stops the compressor automatically .must be leaking on said switch or it knackered .
Old Sep 23, 2011 | 06:15 PM
gouch1's Avatar
gouch1
as above had the same prob few weeks back and we nearly scraped it switch was under 20 quid
Old Sep 23, 2011 | 06:53 PM
2ndGear's Avatar
2ndGear
cheers folks! will get a valve ordered monday
Old Sep 23, 2011 | 09:17 PM
dakar's Avatar
dakar
More than likely the non return valve that leaks back through the pressure along the 6mm pipe that connects them.there is a small rubber pastille inside which wears.u can sometimes make the surface of the pastille flat again with some fine emery
JoeyBoyden
Jan 4, 2024 02:36 PM
IAN RS2k
Aug 18, 2015 07:51 PM
ajamesc
Aug 17, 2015 03:31 PM
col93saphcos
Aug 7, 2015 03:21 PM
