st 170 code error
P0135 - O2 Sensor Heater Circuit Bank 1 Sensor 1
P1131 - Lack Of HO2S11 Switches - Sensor Indicates Lean
P1518 - Intake Manifold Runner Control Stuck Open (Bank 1)
P1131 is probably caused by P0135. Because the sensor heater doesn't work, there are times where there's no signal from the O2 sensor.
p1518 is easy to do. Open up the IMRC box on the bulkhead and chemical metal the return spring in place so it shuts. Did mine a year ago and run loads better but now mine keeps giving that code even though the spring is still ok so sod knows. Theres a online step by step guide on doing it.
As for the o2 sensor Id put a new sensor in but theyre quite expensive and you need the front one
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
