please help with boost! UPDATE
hi every1 im quite new to the cosworth world
i use my car daily and iv now encountered a problem a few days ago car was fine then parked it up went shopping come back out car all sweet apart from boost on my t34 had dropped from 20psi to 10psi checked actuater and waste gate and found waste gate arm had cracked on the weld and was loose so pulled on it and it snaped so got it rewelded connected back up and 10psi again tried tightening actuater no change so removed forged dv and boost now hits 27psi so tryed lowering it and it stays the same and everytime i refit dv it will only boost 10psi please help as im stuck also car has dyno print outs of it being 336bhp at 27psi but on the t3 but was running fine on t34 untill this happend.
Sounds like the DV is leaking boost. If it has a dyno sheet reading 27psi then its obviously been running low boost at 20psi to start with. Is the vacuum pipe still attached to the DV and check for leaks in it.
I was thining the penny washer on the wastegate might have come loose (which I have seen before, it doesnt seal properly and leaks boost down exhaust), but since its fine without the DV, it would suggest this is where the problem lies.
Ive been running mine without a DV on a T34 and its been fine.
was it welded up properly by a specialist or just the top half welded back on.. if the penny inside the housing is not making a perfect seal it will lose boost.. my old turbo looked to be sealing but i put paint on the outside of the penny and held it closed only half of the hole was closing as paint didnot touch the exhaust housing all the way round.. .
What he said, re the wastegate "Penny", turn your ignition on and listed, or alternatively have an assistane do it for you. You should hear the amal valve "Click", if so it's working.
Martin
Martin
Just disconnect the downpipe off the back of the turbo and check to see if the washer is sealing properly. What happens is the shaft it is mounted to slides downwards and the washer doesnt sit in the recess properly. Its easy to spot if this is the problem when you disconnect the downpipe.
You could bypass the Amal valve temporarily to test, just run the pipe from the compressor straight to the actuator. A standard actuator will olny hold around 8 psi when fitted like this and a -31 will hold around 1 bar. If the amal valve isnt operating, I would expect you would get the same results bypassing it. If the AMAL is jammed shut like my previous one, it would overboost.
You AMAL valve should click open and closed when you connect/disconnect the terminal to it. It closes when the ignition is turned, diverting boost away from the actuator, and opens when power is cut to it, allowing pressure to the actuator.
When the engine is running it obtains a live feed again, so should click, by disconnecting/connecting.
Martin
im having to run without bov to get over 10psi i disconected the wires to the amal valve and it boosted around 18psi about were the forged actuater is set i belive also the amal valve still clicks but does seem like it is overboosting when connected also the boost gauge bounces like crazy over 20psi with it conected
Thats what I meant, sorry. When running it should get power and close. Ecu cuts power to it and it opens when max boost pressure is reached. with the engine running, you should get a click by disconencting and reconnecting.
i did think that myself because i only bought it about 1month ago but they all look fine when i first bought it i could adjust the boost with actuater but now cant so thinking gota be amal valve but that dont exsplain the 10psi when bov fitted
tried my dads 3door amal valve today but no change also at high revs and full boost the car missfires slightly around 5k and boost gauge bounces between 20psi and 28psi constant
You can try and find a pump with a gauge on it (I have used the pump off my mountain bikes suspension forks), Attach it to the actuator and see what pressure operates it. Did you check the washer on the wastegate??
my mates was doing the same thing. almost as if the shaft was sitting too low in the housing. It only takes a 1mm of so for it to not seal properly. Not sure about replacing bits. In the end he had his refurb'd at CR turbos I think.
update! just replaced head gasket and put new rear housing on turbo and car still only making 10psi and cant adjust boost by actuator with dump valve disconnected it boost between 25 30psi and boost gauge bounces like crazy and car pops bangs and misfires around 5/6000 rpm
Just a few points to check again.
With the actuator adjusted correctly, and the amal valve removed (ie the actuator plumbed straight into the turbo housing) the car should make
8psi on a -31
14psi on a -34
These are the approx lifting pressures for these actuators without boost control (amal or beled valve). These are figures from MSDs website.
If yours is boosting to 28-30psi in this state, then you have the arm on the actuator tensioned incorrectly, the actuator itself is knackered or the wastegate is sticking. It only needs to be 1/2 of hole too short, and then attached to wastegate arm. This will give you around the above boost levels.
Once your happy this is correct. You need to attach the amal valve. Even with the amal fitted it cant make less boost than the above unless theres a leak between turbo an inlet, or the wastegate is leaking boost (but this would have been apparent in the above situation also).
If its making too much boost with the amal valve fitted or the same as without it fitted, then the valves either faulty or its plumbed in wrong.
If your still not sure, id get it off to a tuner as suggested, to get it checked before you melt something.
8psi on a -31
14psi on a -34
Yes so clearly as I say the D/V is the problem, so without this you have boost, albeit a tad to much by the sounds of what you describe.
Sounds like the actuator is adjusted incorrectly as said.
Martin
Martin
no matter what you do with actuator it will not adjust boost with or with out dv it used to before this problem started also tried 3 dv and all do the same so deffo not dv could it be map sensor or amal wiring?
Firstly, you say it Runs 10psi with DV fitted but 27psi without. Id say the DV is knackered, spring or vaccum not sealing under boost.
Second of all, You mention it ran a t3 on dyno sheet but now has t34.
Id say the misfire is unrelated to the DV and could be down to the chip not being setup for the T34??. Ecu is detecting overboost and cutting the amal valve in hence the misfire etc. Sounds plausable. If this is the case, you have two different issues, the latter could cause serious engine damage.
Personally, if you not 100% sure of the current map setup etc, id pay the money and have a new chip done for the current setup by someone like MSD.
The actuator is what controls the boost, it's a purely a physics affair, pressure overcomes the strength of the actuator will actuate the wastegate (open it) hence the name.
You could have the vaccum hoses connected incorrectly though, or one has a leak, also as said you will need a remap if you haven't done so for the new turbo!
Martin
Martin
i dont know if its been remapped for new turbo coz i bought it with the t34 and it did run spot on also its a ahmed bajoo chip in ecu the rolling roads for when t3 was fitted was 4 years ago
If when removing the DV your plugging the vacuum hose at the DV end (ie your using the same section of hose) and it then starts gaining boost, then it cant be a leak in the pipe and has to be related to the DV. Without the DV connected, it would appear that the leak has gone, and now you are getting overboost, causing the ecu to cut power to the Amal valve, which will drop the boost (sends pressure to wastegate) which could be why the boost is dropping and rising (amal valve opening and closing).
As said by Martin, both the actuator/wastegate and DV are simple devices that just open when overcome by a set level of boost.
Without knowing the ins and outs of the map setup, your playing with fire just adjusting actuators etc. First thing I did when I bought mine was to get a new chip. £100 for a basic one from MSD, but at least i know it setup for the correct injectors, map sensor, actuator set for peak boost etc.
Thats the trouble when buying cossies. People remove parts, swap parts before they sell the car. And without knowing 100%, its just too risky IMO.
Take it to a tuner bud, and get it all setup properly, then you know your starting from a blank canvas
