msd 380 conversion tt t34 55ar
Old Sep 16, 2011 | 04:13 PM
mark r's Avatar
mark r
Default msd 380 conversion tt t34 55ar
got my new chip and injectors today but there was no info on boost setting and co.can anyone tell me what boost (psi)should be safe to run in car.
(everything standard)
mark
Old Sep 16, 2011 | 05:50 PM
conor.rst's Avatar
conor.rst
I think your safest bet is to ring msd and ask them pal
Old Sep 16, 2011 | 07:13 PM
The Youth.'s Avatar
The Youth.
on a road car a peak of 30 psi for reliability IMO
would expect it to hold about 26 as the revs rise
steve
Old Sep 16, 2011 | 09:18 PM
LHD220Turbo's Avatar
LHD220Turbo
i had a t45.55 with 55lbs blacks
make sure you've set base idle first
co% is between 2.5-2.7
i ran 2 bar (32psi) peak
co% must be set when engine is hot & nothing electrical running (stereo, cooling fans etc)
this is assuming your running no lambda
Old Sep 18, 2011 | 09:13 PM
mark r's Avatar
mark r
yes correct not running lamda,but me being stupid never turned the paper over to read writing on the back which tells me what boost/co settings will be.says 32psi peak hold 26psi.
mk3ste
Oct 17, 2021 10:09 AM
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
