plumbed in fire extinguisher pipe size needed.
Old Sep 15, 2011 | 07:34 PM
andy escos's Avatar
andy escos
Question plumbed in fire extinguisher pipe size needed.
im using a lifeline zero2000 extinguisher .
which size pipe do i use as there is 6mm,8mm,& 10mm & how many jets do i use in car & bay the tank is behind the front seats all fuel lines are braided.
Thanks Andy.
Old Sep 15, 2011 | 07:58 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Not sure about the size(10mm is ringing a bell but not 100%),but i had 2 jets under the bonnet, one pointing to the inlet and the other on manifold side,then one was pointed towards the bottom of my seat and then one in the boot pointing at the tank,not sure if thats the correct arrangment
Old Sep 15, 2011 | 08:29 PM
rallycross's Avatar
rallycross
pipe size depends what nozzle is on the extinguisher, the new ones are 6mm I think my previous one was 10 mm.
Have got one in the dash pointing at me and one in the engine bay, not sure what the best point to aim at will be for your car.
Old Sep 15, 2011 | 08:38 PM
markk's Avatar
markk
Never have any in the car, there are pro's and con's - the chance of fuel igniting in the car is very slim compared to under the bonnet, if it accidentally goes off then you have a lot of cleaning to do inside, and very embarassing if your in it.
Only under the bonnet for me.
Old Sep 15, 2011 | 08:50 PM
andy escos's Avatar
andy escos
the outlet on my cylinder is 10mm but that seems a bit large do you step it down or do i run it at that size .
i see where your coming from Mark ,but what size pipe.?
Old Sep 15, 2011 | 09:05 PM
FlashRS's Avatar
FlashRS
Hi, I would say 8mm, best to ask lifeline direct, each type is calibrated to use a size, if its to big you wont have enough pressure to push the foam out!!
Or have a chat with the boys at FEV, thats what they do, helped me when I redid my system after the fire! there number is, 01243555566.
Johnny Knoxville
Sep 30, 2015 07:21 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
mpilk
Sep 27, 2015 09:21 AM
