2wd /4wd prop shafts
can anyone tell me the differences between a 2wd prop and a 4x4 prop are the flanges the same ie on the diff side and is the bolt pattern the same the gearbox end , is the any difference in lenght also.
iam running 4x4 but with 2wd rear diff that why iam asking
any help would be great
cheers paul
cheers paul
The 2wd gearbox end has a shaft that goes into the box. The 4wd has a bolt on shaft to the gearbox. The rear ends to the diffs are the same. I ran a 4wd Escort with a 2wd diff using a 4wd prop
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
