what glue?
I used Evostick on my saph cosworth, still stuck to this day. Took a couple of tubes and used a bodge spreader to spread the glue, had to remove the thin layer of foam off the head cloth to ensure it stuck. Tried various spray glues but all failed
Make sure u open a window coz its got quite a kick. Steve
Was easy to drop the lining out just had to recline front seats nd drop the back seats nd take it out through the boot. The foam came off easily with a small hard brush
The hardest bit is getting started gluing but once you start the rests a doddle. Am sure the glue was bostick evostick, in a silver tube with red writing.
Vacuman
Sep 22, 2015 12:09 PM
