ARP stud and nut kit
Old Sep 12, 2011 | 05:53 PM
royRS's Avatar
royRS
Default ARP stud and nut kit
i'm gonna put my new engine back together but i've got a head that's too much skimmed already and because of that i need to use a multilayered headgasket (have to figure out compression ratio for thickness)
i want to use this with an arp stud and nut kit on my 200 block now have i heard from some people don't do this because block will crack and other people say that nothing's wrong with a stud and nut kit
what is th best to do use 1 or use standard bolts with a multilayered headgasket?
Old Sep 12, 2011 | 05:58 PM
RS500/364's Avatar
RS500/364
I would say not all crack but why chance it i did have it and was lucky the reason it cracks is there to strong and do not move with the heat making them cause the cracking
Old Sep 12, 2011 | 07:51 PM
graham c's Avatar
graham c
am going long studs in mine safer since i,ve heard the same
Old Sep 13, 2011 | 05:41 PM
royRS's Avatar
royRS
going for standard bolts thanks
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
little bram
Sep 27, 2015 07:45 AM
