Advise on a2.0 pinto carburretor turbo charge
Old Sep 12, 2011 | 09:22 AM
Dawie's Avatar
Dawie
Default Advise on a2.0 pinto carburretor turbo charge
Can anyone tell me if it is possible to turbo charge pinto engine from my side draft carburettor and how much bhp I will gain?
Old Sep 13, 2011 | 02:47 AM
robrs2's Avatar
robrs2
Yes.
If its a weber then its a pain to do. If its a Dellorto then you need the turbo kit from a lotus esprit. Bothe need a rising rate fuel regulator. Then you will need to sort the ignition so it retards under boost slightly.
How much power? not much more. I got an extra 60bhp on my EFi pinto at 7psi
Old Sep 14, 2011 | 09:34 PM
clyde 1800's Avatar
clyde 1800
i have one and its boosting 4.0psi which should be closer to 8
im currently in the process of changing to an injected engine this way i can regulate the fuel
atm the car is boosting but not holding boost as it cant tell itself to supply more fuel
Old Sep 14, 2011 | 09:50 PM
Dawie's Avatar
Dawie
Hey, can u please tell me how much bar is 4 psi, and do I need to change my pistons or conrods to run that boost?
Old Sep 15, 2011 | 07:25 AM
robrs2's Avatar
robrs2
4psi is 0.276 bar. No need to change pistons or rods until over 12psi (0.82bar)
Old Sep 15, 2011 | 07:42 AM
Dawie's Avatar
Dawie
and I can run that off my dellorto side drafts?
Old Sep 15, 2011 | 08:26 AM
clyde 1800's Avatar
clyde 1800
your engine should be 100% with no modifications to the block or head only the sump
you will need a closed in carb like this
im doing away with this and putting on an injection system so will probably see a new owner
Old Sep 15, 2011 | 08:38 AM
Dawie's Avatar
Dawie
what will then happen when I put a turbo on a modified engine?
Old Sep 16, 2011 | 08:35 AM
clyde 1800's Avatar
clyde 1800
you need low compession and if your engine has a cam it will fail miserably
if you want to turbo a pinto i suggest you buy a simple pinto engine and bolt it straight on
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
