Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
List of issues Mk1 focus
Old Sep 11, 2011 | 09:15 PM
matts1's Avatar
matts1
Default List of issues Mk1 focus
Evening all, my brother has left me with his ford focus to sort.
2001 1.8l petrol.
Issues are:
Cuts out intermitantly, basically dies when slowing down, dash lights come on and needs to be restarted. Then starts, drives as normal. Only happens now and then.
Could this be the Speed sensor Valve? seems to be a common suggestion.
The car is driven softly and short journeys if this makes any difference.
Next issues:
Engine fans cutting in and out regularly from cold onwards, and heater blower in the car only works on blower 4 nothing else.
Could this be the resistor?
Finally, and maybe coinsidence, but the car cut out the moment I turned off the A/C, didnt think to try it off and on again to see if it did it again, but thought I would mention it.
Did some searches but multiple answers and advice so thought i would list the exact issues and see if it is one thing for each issue, or if it could be multiple possible causes.
Any help is mucho appreciated
Old Sep 11, 2011 | 09:37 PM
user 628729's Avatar
user 628729
It's called the VSS (Vehicle Speed Sensor).
If the speedo drops to zero at the same time while still moving that's almost certainly it.
Common problem, easily fixed.
Fix 1 thing at a time.
Old Sep 11, 2011 | 09:57 PM
martysmartie's Avatar
martysmartie
You say the fans are coming on, they are signalled to do so by the CHT (AKA) CTS sensor, so it could be this causing the problem as well as the stalling problem, assuming, of course, it isn't actually overheating.
Other causes could be air leak, or dicky ISCV or VSS.
Re the fan problem, resistor pack, very common problem, reason it works on position 4 is because it has a direct live for it.
A/C sounds like a idle regulation problem, try applying throttle and then turn on and see if it still stalls. If not then the ECU is either not recieveing the correct input, or not giving the correct output for air compensation to stop to raise the idle speed to stop this from happening.
Martin
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Chas
Sep 21, 2015 08:57 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
saph in dorset
Aug 14, 2015 10:10 AM
