Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
My first mk2 cortina... few questions about suspension etc.
Old Sep 11, 2011 | 01:15 PM
cosworth_wannabee's Avatar
cosworth_wannabee
Default My first mk2 cortina... few questions about suspension etc.
Hi all, just got my hands on a mk2 cortina 1500 super, lagoon blue, 1967 model.
have stripped it all down to a rolling shell so i can start doing a full weld up on it, and as for rot... it isnt looking bad at all.
what i want to know is about suspension lowering and stiffening. ive just spent the last hour searching forums, google etc, seen a couple of posts about coilovers, rs2000 springs, capri leafs on rear etc. but nothing that actually gives a proper answer.
im not looking at racing the car, just more of a cruiser that sits nice, so would be thinking of polybushes all round, stiffer dampers all round, lowering blocks at rear and lowering springs on front, but i cant find out what to use or where to get any from anywhere
can you guys help?
this is my first proper oldskool ford, the oldest previous being a mk3 escort 3i, so alot different in alot of respects.
hope you guys can help, thanks. Aaron.
Old Sep 11, 2011 | 11:11 PM
Less.'s Avatar
Less.
having a mid life crisis
Might be a good idea to sign up too, Turbosprt as they are very into old fords on there
Old Sep 14, 2011 | 11:53 PM
ram's Avatar
ram
Has a large member
My Mk2 Tina uses Capri shocks and lowering springs on the front end. enables you to then run the capri 2.8 brakes too
Old Sep 15, 2011 | 05:15 PM
cosworth_wannabee
Thanks alot mate, could you go into that a bit further?..
will and capri front struts and springs fit?? and do they go straight on without modding or will i require other parts??
struggling to find info on this, if anyone knows of any other sites/forums suited towards my need that would be a great help!
Old Sep 15, 2011 | 10:16 PM
ram's Avatar
ram
Has a large member
To be honest mate i bought the car with them already on but they're mounted to the standard strut tops. best bet is to get onto oldskoolford.co.uk as they will give you the answers you need
IainRS1700T
Sep 25, 2015 06:44 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
truffleshuffle
Sep 10, 2015 09:35 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
