.55 exhaust housing
Sep 10, 2011 | 06:06 PM
.55 exhaust housing
how laggy would people expect a t35 with the above exhaust housing to be on a standard cosworth engine but with stage 3 parts (3 bar,greens,chip,cooler,exhaust and filter)
Sep 10, 2011 | 06:50 PM
they go great on standard compression,cams head etc
Sep 10, 2011 | 09:03 PM
bosh greens 0280150803's are too small for that size turbo watch your boost levels
Sep 10, 2011 | 09:39 PM
The power don't drop off like a .48 at higher revs
I only found it a little more laggy than the .48 but when your on it you don't notice
Steve
Sep 10, 2011 | 09:42 PM
its peaking at about 14psi but not starting to come on boost till about 3000rpm
Sep 10, 2011 | 09:47 PM
Quote:
Originally Posted by
jonesymk2
Im getting well over 1bar of boost on my TT T38 @ 3000rpm
Steve
Sep 10, 2011 | 09:55 PM
once its on boost it doesnt seem to drop off atall up to 6500rpm which is when ive changed gear
Sep 10, 2011 | 09:58 PM
i will have to get the actuator changed and on a proper bracket then get it checked and setup
Sep 10, 2011 | 10:15 PM
I shall reiterate my warning, watch your boost levels particularly at 6500 + on t35 turbos on greens, it needs to be on its way down from 6 k upwards
Sep 11, 2011 | 07:17 AM
would i be better swapping to greys then,do you set cars up still and if so could you pm me a rough price please
Sep 11, 2011 | 07:57 AM
I had a t35, 500 cooler, and 55's on my old saff and it wasn't shy lol.
Sep 11, 2011 | 08:00 AM
jonesymk2
The old fart still sets cars up, he ain't that bad at doing it either lol
Steve
Sep 11, 2011 | 08:21 AM
would greys be better or siemens 55s
Sep 11, 2011 | 08:29 AM
Siemens would be my choice.
Sep 11, 2011 | 08:40 AM
i will have to look into them at the end of the month then
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
